My 1200W Kenmore Elite microwave has the interior light out. The turntable also does not move. It seems to be cooking fine. How do I replace the light? What type of light does it use? Also, is there a fuse to replace to make the turntable move again?
S/N 302KM00028
Thanks!
If the microwave is heating, but the lights and the turn table are not working then the problem most likely is a bad control board.
If that is the case, can the control board be replaced???
Yes, it can be replaced but you have to order the part through Sears only.
