mpickell
#1 Posted : Tuesday, September 27, 2011 9:07:17 AM(UTC)
mpickell
I am trying to troubleshoot a Maytag MGR4452BDW oven. I am not sure of the age, so i am guessing it is over 5 years old.
The control panel at the top works fine. I can set it to "Oven", adjust the temperature, and I hear a "click" like it is trying to start the oven ( the click reminds me of the click you hear a house thermostat make when it kicks on the furnace )... but nothing at all happens in the oven.
(Natural) Gas flows to the burners on top of the stove, but i'm seeing absolutely nothing down in the oven.
This is a pilot-less oven, and i'm wondering if maybe the ignition element in the oven might be broken? I would assume that if that element doesn't heat up, then the gas to the oven would not flow either.
Any ideas? Thanks!
mpickell
#2 Posted : Tuesday, September 27, 2011 4:53:04 PM(UTC)
mpickell
Also...
The broiler doesn't work. Three of the burners light if a match is used, one lights automatically still from the spark. The one that lights automatically is the back left burner.
I'm thinking it is either the spark module ( based on the burners starting to not work ), or the ignitor... But I'm leaning towards spark module right now..
Any ideas?
Thanks!
mpickell
#3 Posted : Monday, October 17, 2011 5:56:14 AM(UTC)
mpickell
Turns out it was the ignitor... see the response here: Maytag oven and broiler not working
Gas Oven not Heating at all burners OK (Oven Repair (including Ranges and Cooktops))
by tattell 2/7/2012 12:01:59 PM(UTC)
Amana oven not heating at all (Oven Repair (including Ranges and Cooktops))
by dmay21 10/5/2010 10:35:25 PM(UTC)
Gas oven not heating at all! (Oven Repair (including Ranges and Cooktops))
by krakka 8/14/2008 3:02:27 PM(UTC)
