amarch8
#1 Posted : Wednesday, April 22, 2009 5:35:05 PM(UTC)
amarch8
Ice Maker Crushes, Doesn't Cube, Also Need To Replace Actuator In Water Dispenser
woodchuckie
#2 Posted : Wednesday, April 22, 2009 6:47:27 PM(UTC)
woodchuckie
You have a solenoid that switches the ice crusher off and on. When it's off you get cubed ice. It could be the switch not changing it to cubes or the solenoid could be stuck. Part 45 is your solenoid. http://www.appliancepartspros.com/sect/9/u/8/9u8lwfrxjg.gif
Part 24 on your dispenser parts is the actuator Replacement parts for FRG FRS26SM4AW0 | AppliancePartsPros.com
