bskeen
#1 Posted : Wednesday, April 22, 2009 11:59:14 AM(UTC)
bskeen
I purchased a dishwasher from a friend a few months ago. It worked when he had it hooked up. I finally tried to hook it up and there is no water when you turn it on. It lights up and you can hear the motor. Could it be a bad inlet valve?
#2 Posted : Thursday, April 23, 2009 2:48:51 AM(UTC)
Here is the parts breakdown
Replacement parts for WHIRLPOOL DU1100XTPB3 | AppliancePartsPros.com
Here is a tech sheet
https://www.servicematters.com/d...0Sheet%20-%208535451.pdf
It could be but it also could be a number of other things.
Check that a wire has not come loose during the move.
I would check that the float is not stuck in the up position, the switch underneath should be activated (held closed by the float rod)
If OK
Check that the water inlet valve has continuity (approximately 1000 ohms)
If OK
Check if the valve gets power at the start of the cycle (120 volts)
If yes
Valve is either shot or it's input side filter screen is clogged up.
Also check to be sure the unit is getting water. Loosen the fitting at the inlet valve to see if water starts dripping out.
If no voltage
Check that the float switch is actually closed (0 ohms), just because the switch is activated does not mean that it's contacts are closed.
Check that a wire has not come loose at the control board.
METER
If you do not own one I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
No water in dishwasher (Dishwasher Repair)
by micnic 10/8/2011 8:43:36 AM(UTC)
No water in dishwasher tub (Dishwasher Repair)
by frigidish 5/10/2011 8:59:02 AM(UTC)
No Water in Dishwasher (Dishwasher Repair)
by claudebo 12/13/2008 6:39:20 AM(UTC)
