My dishwasher doesn't work. On the display screen is a bunch of error codes from 2H through 7H. What's wrong and how do I fix it. David
Rank:: Advanced Member
Cannot find info on the given Model Number please check it. Can find info on a XTSQ1.
H is usually Delay Time perhaps the delay key is shorted. Try shutting power off to the unit for half an hour or so, to see if it will reset. |
THIS FORUM IS DEAD!!!!!!! |
