wcaddigan@aol.com
#1 Posted : Sunday, September 25, 2011 4:50:44 PM(UTC)
wcaddigan@aol.com
When we first put the dryer on it makes a squeaking sound but within 5 minutes it goes away and clothes dry fine. Is the belt starting to go?
#2 Posted : Monday, September 26, 2011 12:42:11 PM(UTC)
Replacement parts for WHIRLPOOL LER6611LQ0 RESIDENTIAL DRYER | AppliancePartsPros.com
[COLOR="DarkRed"]Is the belt starting to go?[/COLOR]
I doubt it is the belt though it may need replacing.
More likely culprits are the belts idler wheel, a rear drum support roller, the front drum bearing ring or motor bearings.
Guest (4)
