Boostedracing
#1 Posted : 16 years ago
Boostedracing
I did a bad thing today. I was changing out the lightbulb and the bulb broke off from the threads. I put the glass back in to try and unscrew the threads. When I did, the bulb sparked and shorted out something in the microwave. Now, the control panel works, but the turntable doesn't as well as there are no lights inside and no heat. I took all of the access panels off and found a fuse, but it only affected the control panel. What did I burn/blow up when I shorted out my M/W? Help...:confused:
#2 Posted : 16 years ago
Most likely that short caused damage to the control board.
- The part number for the control board is AP3181307
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL MH1150XMQ3 | AppliancePartsPros.com
