AppliancePartsPros.com
Appliance Repair Help
Microwave Repair
Whirlpool microwave hood shorted while changing bulb
I attempted to change the bulb over the stove. When I screwed it back in, the bulb popped and shattered.
Now the microwave won't start.
The control panel seems to be functioning properly. It accepts input and counts down, but does not start the appliance.
No fan, turntable or buzz.
The interior light is on.
Is this likely a control panel problem, a fuse, or something I can't fix?
Thank you.
Bump
I'd like to get a part on order.
Can anyone advise?
Rank:: Member
Whirlpool microwave model MH1150XMB-3 I have the same issue, I attempted to change the bulb over the stove. When I screwed it back in, the bulb popped and shattered. Now the microwave won't start. The control panel seems to be functioning properly. It accepts input and counts down, but does not start the appliance. No fan, turntable or buzz. The interior light is on. Is this likely a control panel problem, a fuse, or something I can't fix? Thank you. Read more: http://forum.appliancepartspros...-bulb.html#ixzz1bYEL3xfT http://forum.appliancepartspros.com
Microwave Repair
