Bellamorabito
#1 Posted : 13 years ago
Bellamorabito
I have power to the washer, but no cycles function. After a period of time, I loose power aktogether; as if an inyternal breaker shuts the machine off. Any suggestions would be helpful. Thanks
sidfink43
#2 Posted : 13 years ago
sidfink43
You need to tell us in more detail what is happening, for example does it fill and if you move the timer by hand will it drain.
The problem sounds like the timer is the issue but you will need to change it out to be certain, assuming you are sure it is getting power.
Part number: AP4024921
