rpushee
#1 Posted : Friday, November 30, 2007 4:48:03 PM(UTC)
rpushee
Has anyone else had the GE Service mess up your dishwasher when the performed the recent recall?
Ours hasn't worked right since they left. We got them back and the tech claimed it must be the incoming power connection.
He didn't believe it could flood the floor. But, then we found that the float switch was jammed and bulgeing -- so the float couldn't open the circuit. I fixed that and no more floods.
But, there is still a bad connection somewhere in the new harness they installed. If you jiggle the harness just right, it starts. But, usually craps out about the time the soap probably tries to open. I also found a totally disconnected terminal which might go to the heater. Put that back, but still quits.
Thanks a whole lot for the great (dis)service GE!!
Ron
