Larry129
#1 Posted : Tuesday, April 21, 2009 4:05:04 AM(UTC)
Larry129
When tested with a multimeter, the element shows the recommended 10 Ohms resistance, but shows no continuity when tested with a simple lighted continuity tester. Is the element still bad?
#2 Posted : Tuesday, April 21, 2009 4:45:13 AM(UTC)
I would trust a multimeter over a continuity tester any day of the week.
You do not know what the continuity tester considers as continuity re: if it is 5 ohms then it will show the heater as an open.
I would say your element is OK.
Kenmore dryer element does not shut off, keeps heating after door is opened (Dryer Repair)
by sydnee67 9/23/2020 9:03:31 AM(UTC)
Dryer element cools down when door shuts (Dryer Repair)
by Bigcountry7 11/19/2016 3:12:31 PM(UTC)
Dryer Element not Heating (Dryer Repair)
by TupeloWx 6/2/2015 6:39:48 PM(UTC)
Dryer elements are hot even when drum not turning (Dryer Repair)
by buddy1885 1/13/2014 5:31:59 AM(UTC)
Electric Dryer Element not cycling (Dryer Repair)
by Wawe 12/26/2013 3:32:08 PM(UTC)
dryer element is too hot after replacing (Dryer Repair)
by kmcentaurgmail.com 12/10/2013 3:48:59 PM(UTC)
Dryer element will not shut off (Dryer Repair)
by topperforever 12/1/2011 2:41:04 PM(UTC)
Whirlpool dryer element heats on fluff (Dryer Repair)
by 1911bud 8/26/2011 3:45:56 PM(UTC)
dryer element heats hot on every temp level (Dryer Repair)
by sbabler 6/12/2011 1:19:39 PM(UTC)
electric dryer element on briefly (Dryer Repair)
by dianedebuda 4/29/2011 7:03:49 AM(UTC)
Range and dryer elements will not work (Oven Repair (including Ranges and Cooktops))
by fasteddie11 4/26/2011 11:00:31 AM(UTC)
what dryer element to buy for this model?? (Dryer Repair)
by brendabloods 4/21/2011 9:26:13 AM(UTC)
Dryer element on-drum not turning (Dryer Repair)
by golfindaddy 10/9/2010 3:14:28 AM(UTC)
Maytag dryer element replacement (Dryer Repair)
by jadeck 9/19/2010 3:41:07 PM(UTC)
dryer element? (Dryer Repair)
by macmom 6/9/2010 5:28:45 PM(UTC)
