C. Pierick
#1 Posted : Monday, April 20, 2009 10:36:32 AM(UTC)
C. Pierick
Our freezer is accumulating ice and it tends to climb over the edge between the chest and the seal. Is the seal supposed to have a magnetic feeling when you try to open the freezer? Ours does not. If we need to put in a new seal is it an easy project or do we need special tools to do this.
C. Pierick
#2 Posted : Monday, April 20, 2009 10:41:48 AM(UTC)
C. Pierick
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
#3 Posted : Monday, April 20, 2009 1:43:56 PM(UTC)
Very likely the problem is a bad door gasket. This part is not too difficult to replace yourself and do not need any special tools, just a screwdriver. Remove the freezer door and put it on a flat surface. Loosen the screws around the inner door panel and pull out the old gasket. Put in the new gasket. Remount door and tape door shut for several hours to let the gasket form all around.
- The part number for the door gasket is AP2113366
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE MFC05M0BW4 | AppliancePartsPros.com
