hi my washer will only light up control panel locked. i replaced the control board same thing (it worked last time) how do i trouble shoot it? i'm stuck if it does anything at all sometimes you can get it to say 25 mins left on load but the door doesn't lock or any thing. thanks
Originally Posted by: Gene  :( is there a way to check the door latch switch ? it will not let me get to the code mode it just stays locked thanks
Try to unlock the door manually as described in the Service manual (the link is in the previous reply).
Originally Posted by: Gene  Try to unlock the door manually as described in the Service manual (the link is in the previous reply).
Gene. hi, again its not the door looked its the panel says its locked and it will not let you do anything codes or nothing i'm begening to think i got a bad control panel. i think its going to die, i'm threating it with a trip to the scrap yard any help is appreciated thanks:(
Check the door latch switch as described in the Service manual.
Originally Posted by: Gene  Check the door latch switch as described in the Service manual.
Gene. hi, everything points toward the central control unit, i'm going to order it, thanks for the manuel that was a life saver let you know what happens seeya
You are welcome. We are glad you were able to fix it.
