Freezer side is working but the cool side is not...I am not sure if it is the blower or what and how to replace it..any intake would be appreciated:)
Thanks Steve
You can hear the fan blowing in the freezer if it's running. It's behind the back cover in the freezer if you need to replace it. Make sure the coils behind that cover are not ice up blocking the air flow.(auto defrost problem) There is a vent between the freezer& fridge where the air is blown to the fridge by the fan. It is opened and closed by the fridge temp control. Make sure it's open allowing the air to enter the fridge. Here is the diagram of your unit. Fan is in the control section. Replacement parts for FRG FRS26R4CBB | AppliancePartsPros.com
