No ice. I do not hear the water flowing at all through the tube. Anyway to start it back?:confused:
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
After you have water in the ice mold it may start cycling on it's on after it freezes and dumps the ice.
