Condenser coils werent cleaned properly, and the refrig wasnt working very well. After cleaning the coils it works fine, but the knob on the defrost timer was turned. The inside of the doors, around the edge, is warm. How do you turn the defrost back to normal. If this is the problem.
Originally Posted by: curtisr69 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Condenser coils werent cleaned properly, and the refrig wasnt working very well. After cleaning the coils it works fine, but the knob on the defrost timer was turned. The inside of the doors, around the edge, is warm. How do you turn the defrost back to normal. If this is the problem. If the defrost timer is working properly, after being in the defrost cycle for approximately 20 minutes it will automatically terminate the defrost cycle and resume cooling. The warmth in the walls could be caused by the condenser fan not running. It blows on the condenser which is near the compressor under the fridge at the back.
