CandyL
#1 Posted : Friday, April 17, 2009 3:15:52 PM(UTC)
CandyL
Hi if anyone can help I have an Amana frig and the freezer which is on the bottom, is fine but the frig on top is not cold at all and even when I turn it all the way up it does not get cold. I need to know if this model has 2 thermostats and if it does where exactly is it.
libertyappl
#2 Posted : Friday, April 17, 2009 5:42:44 PM(UTC)
libertyappl
Look in the freezer to see if you see any frost or ice buildup anywhere. if so this is probably an indication of a defrost problem. Start by locating the defrost timer in the control area, there should be a part that is turnable, turn it a little at a time to see if the unit will go into defrost cycle. Post your results.
Replacement parts for AMANA ARB190ZCW | AppliancePartsPros.com
#3 Posted : Friday, April 17, 2009 6:50:31 PM(UTC)
Is the freezer fan running. It is required to push the cold air into the fresh food section.
Freezer working fine refrig not cold enough (Refrigerator & Freezer Repair)
by Tucson_Mike 8/8/2015 7:01:52 PM(UTC)
frig not cold (Refrigerator & Freezer Repair)
by buck hunter67 4/24/2015 5:22:19 PM(UTC)
Freezer and frig not cold enough (Refrigerator & Freezer Repair)
by Chargersrlh 4/9/2013 2:31:26 PM(UTC)
GE refrig not cold enough (Refrigerator & Freezer Repair)
by GaryVA 11/18/2012 11:56:13 AM(UTC)
refrig not cold & water in it (Refrigerator & Freezer Repair)
by kjbh1960 6/11/2012 6:17:44 AM(UTC)
Freezer not Freezing and Frig not cold enough (Refrigerator & Freezer Repair)
by FrancyJ 4/2/2012 3:37:52 PM(UTC)
Another Freezer/Frig not cold enuf..but unique !! (Refrigerator & Freezer Repair)
by Barry2 9/29/2011 4:07:51 PM(UTC)
Freezer fine, refrig not cold enough (Refrigerator & Freezer Repair)
by boolabonga 9/2/2011 4:27:19 AM(UTC)
Both freezer and refrig not cold (Refrigerator & Freezer Repair)
by JTIngram 8/24/2011 7:32:29 PM(UTC)
freezer working good frig not cold no frost on freezer coils (Refrigerator & Freezer Repair)
by ch123 6/12/2011 11:05:01 PM(UTC)
Whirlpool Roper: freezer/refrig not cold enough (Refrigerator & Freezer Repair)
by Jzerb 6/12/2011 8:12:36 AM(UTC)
Top of Freezer and top of Frig not cold enough on side by side (Refrigerator & Freezer Repair)
by PleaseHelp 11/13/2008 8:07:43 AM(UTC)
sub zero 532 - compresser will not stay on, refrig not cold (Refrigerator & Freezer Repair)
by malisdad 9/15/2008 11:54:35 AM(UTC)
Freezer and Frig Not Cold (Refrigerator & Freezer Repair)
by rogo56 3/25/2008 11:42:27 AM(UTC)
Refrig not cold (Refrigerator & Freezer Repair)
by bwall117 12/12/2007 2:14:42 PM(UTC)
