I need to replace the oven door gasket and would like to find a drawing of how to remove and replace the gasket.
Remove the door from the oven. Place it on the flat surface with the door handle facing down. Remove all screws holding the inner door panel and lift it up. Now you have access to the door gasket. Unfortunately there are no drawings. - The part number for the door gasket AP2009325 Gene.
