davide
#1 Posted : Friday, April 17, 2009 8:48:10 AM(UTC)
davide
Freezer will go through like a cycle of warming up then cooling back down. This lets things like ice cream melt a little then refreeze. It does not happen consistantly. Could this be from a bad freezer temp control, refrigerator temp control, or the freezer fan switch? This is my father-in-law's frig and he seems to think when he giggles the fan door switch it causes the fan to go on and off.
If it is the freezer temp control, where is this control located?
woodchuckie
#2 Posted : Friday, April 17, 2009 11:48:29 AM(UTC)
woodchuckie
The fan not running at times could be the problem and the door switch does cut it off when door is opened. If the connections are loose or the switch bad that could be the problem.
If the compressor is cutting off and the freezer hasn't reached the proper temp it could be the freezer temp control.
davide
#3 Posted : Sunday, April 19, 2009 12:24:13 PM(UTC)
davide
Where is the freezer control located in the Frigidaire frs26znhw1?
woodchuckie
#4 Posted : Sunday, April 19, 2009 2:31:07 PM(UTC)
woodchuckie
Part 21 on the diagram of your controls. http://www.appliancepartspros.com/sect/s/0/r/s0r6nds8jg.gif
How do I detach aluminum wire, freezer temp control? (Refrigerator & Freezer Repair)
by Carrie Koplinka-Loehr 12/7/2007 7:05:31 AM(UTC)
