I need to remove my Kenmore ice maker but I can not disconnect the wire harness from the back of the refrigerator. I have aplastic clip with 3 wire 1 water supply I tried to pull this clip out but no luck and I can not see any where to squeeze or flip the clip open any help is appreciated and Thanks in advance.:mad:
Using a flash light look for a lock on a side of the harness plug.
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Using a flash light look for a lock on a side of the harness plug.
Gene. That was exactly what I needed to know. I have now removed the ice maker and did not break the clip. Thanks Gene!
You are welcome. I'm glad it was that simple.
