larena
#1 Posted : Saturday, July 28, 2007 8:42:17 AM(UTC)
larena
My chest freezer is cooling just fine, but 1-2 times a day it is leaking water all over the place. I've de-frosted it, but the problem is just getting worse. the unit is almot 10 years old, is it worth fixing? If so, does anyone know where I could start looking for the problem? I do not have the manual, nor can I find much info on the web. Help!
larena
#2 Posted : Saturday, July 28, 2007 12:55:21 PM(UTC)
larena
The water is appearing on the ground below the freezer. The freezer is currently frost-free, and the temp. seems to be staying below freezing
#3 Posted : Sunday, July 29, 2007 10:45:45 PM(UTC)
larena
Your freezer has a drain plug on the floor and drain goes under the freezer. Check the plug and were the drain hose goes. The problem is some were there.
