My dryer stopped bllowing hot air any idea what part I would have to replace to get it to blow hot hot again?
Here your parts Replacement parts for WHIRLPOOL EL4030VW0 | AppliancePartsPros.comCould be a number of things. First flip your breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. Better yet measure the plug for 240 volts. Could be Item 6 in section 3 is blown. This is a thermal fuse. If it is blown be sure to clean the interior and your vent system. Could be the heater is blown. If you do not own one I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long. If it saves ordering one unnecessary part it has paid for itself and you end up owning a useful tool. Most places will not let you return electrical parts so if you order it, you own it. A couple things to watch when measuring ohms and continuity 1. Always remove power from the machine otherwise you could blow your meter. 2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path. 3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale's dynamic range. There is a good STICKY at the start of this forum about it's use. |
THIS FORUM IS DEAD!!!!!!! |
