The right side of my JenAir Gas Stove will not light. However if I remove the burner piece from the left side and place it on the right side it will light. I do recall when I spilled water a week ago, that is when it stopped working? Is there something I should do to clean out the burner unit? Thank You for your time. Regards, Stephanie
