rjenkins7
#1 Posted : 18 years ago
rjenkins7
I have a Whirlpool Gold top loading washer. There is no model number available. I have checked the entire washer and also spoken directly with Whirlpool. The data plate cannot be found.
The leak appears to be coming from the bleach reservoir. It leaks during the fill cycle and the water that leaks is soapy.
I plan to remove the part and take it to an appliance part store. Maybe they can identify it since I have no model number.
Any ideas?
ApplianceJunk
#2 Posted : 18 years ago
ApplianceJunk
It's most common for the whirlpool made direct drive washers to leak from one place, the water pump.
You could check this by running some water into the washer and then pump it out once it starts to leak.
Tip the washer back and look up under it. The water pump is located front, bottom center. You should see were it drips yet after you pump the water out.
Here is a little guide that shows you the water pump.
Washer repair guide
#3 Posted : 18 years ago
rjenkins7
Did you check the frame under the lid for the name plate? The proper model number is very important for better diagnosis.
gumm_jam
#4 Posted : 17 years ago
gumm_jam
Hi Gene,
I have a Kenmore Dishwasher (model number 17735791) and every 6 to 10 times of use it leaks water below the door. I have already replaced the gasket that goes around the door, but it continues to leak, any ideas to what i could do next??? thanks
#5 Posted : 17 years ago
Did you see a bubbles inside the dishwasher when it was leaking?
What is the complete model number of the dishwasher?
gumm_jam
#6 Posted : 17 years ago
gumm_jam
Hi Gene, There is only water leaking, no bubbles on the outside we never opened it when it leaked to check for bubbles inside. The complete model number is A Ultra Wash Dishwasher, Kenmore, Model- 17735791 and the serial number is FH1013551,
#7 Posted : 17 years ago
The only what I can recommend at this time is to wait until it will leak again, open the door and check for bubbles inside.
Did you use a rinse aid?
P.S. There are suppose to be 3 more digits in front of the model number.
GSD5120D00BB GE dishwasher leaking at the bottom corners (Dishwasher Repair)
by ron Minervino about a year ago
Dishwasher Leaking Kitchenaid KDTE334DSS0 (Dishwasher Repair)
by Bscott46 2 years ago
Old Maytag 712 Washer Leaking at Injector Valve (Washer Repair)
by ronp99 3 years ago
Maytag top load washer leaking oil from transmission (Washer Repair)
by Rdchapman2 3 years ago
Maytag dishwasher leaking and smoking (Dishwasher Repair)
by Guest 3 years ago
LG Dishwasher Leaking When First Turned On (Dishwasher Repair)
by artriumph 4 years ago
Kenmore Washer leaking ONLY Hot water during Fill (Washer Repair)
by colbey 5 years ago
Maytag Dishwasher LEAKING underneath (Dishwasher Repair)
by bakerid2000 6 years ago
Whirlpool dishwasher leaking bottom (Dishwasher Repair)
by nkaufman1 6 years ago
Whirlpool washer leaking and won't fill with water (Washer Repair)
by christyhecht 7 years ago
Bosch Dishwasher Leaking into base (Dishwasher Repair)
by Canadianice 7 years ago
Dishwasher leaking underneath [PHOTOS] (Dishwasher Repair)
by jd514 7 years ago
Bosch Nexxt 500 Series Washer leaking (Washer Repair)
by neustkg 8 years ago
Kenmore Series 80 washer leaking water above clutch assembly (Washer Repair)
by hallway 8 years ago
Kitchenaid dishwasher leaking under door (Dishwasher Repair)
by chasethedream 8 years ago
