Dixie Dutchman
#1 Posted : Tuesday, April 14, 2009 5:15:21 PM(UTC)
Dixie Dutchman
The top oven in my stack wont heat. I had a appliance repair company replace the control panel about 2 months ago and shortly after that just the top stopped heating. No codes are visible and neither the bake or broil heat up. Your help is much appreciated. Thanks. Sincerely, Doughy in the middle.
#2 Posted : Wednesday, April 15, 2009 1:51:04 PM(UTC)
Have you run the self clean recently (prior to this happened)? Looks like the oven shutdown thermal fuse (#37 on the diagram) is blown due to overheating.
You can check it as described in the Tech sheets (page 6)
- The part number for the oven shutdown thermal fuse is AP3885687
Here are the break down diagrams and Replacement parts for WHIRLPOOL RBD305PDS14 | AppliancePartsPros.com
