I changed out the ice maker and still no ice. I checked for continuity at the thermal fuse and its good. Water dispensor is working. shorted out T and H and nothing happens. Don't know what else to do.
I had to replace the little electric water valve that sends water to the ice maker when it calls for it. It is located where your water line attaches to the fridge.
Originally Posted by: sosofresh ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I changed out the ice maker and still no ice. I checked for continuity at the thermal fuse and its good. Water dispensor is working. shorted out T and H and nothing happens. Don't know what else to do. Open the freezer door. Make sure the "on-off" switch on the right side is "on". Push in the flopper door on the left side and watch the status LED on the right side. Post the results. Gene.
