edgemere
#1 Posted : Thursday, September 15, 2011 8:31:46 AM(UTC)
edgemere
My Jenn Air glass cooktop cracked, and I have ordered a replacement for it. The existing cooktop fits into my granite countertop, and can be lifted right out. Will I need any additional parts other than the glass top itself (i.e. clips, foam tape, etc) to complete the project? Thank you.
#2 Posted : Friday, September 16, 2011 6:40:25 AM(UTC)
Replacement parts for JENN-AIR CCE3401B SURFACE UNIT- ELE | AppliancePartsPros.com
It does show foam tape (Item 1 in Section 2) which you should replace. I doubt you will be able to reuse the old stuff.
Also here is the install sheet.
https://www.whirlpool.com/digita...ns%20-%20AAECTDIRAII.pdf
Part number: AP4090121
If you click on the above another page will open with questions/answers on it's install.
edgemere
#3 Posted : Friday, September 16, 2011 8:58:02 AM(UTC)
edgemere
[Thanks very much for the quick response.
quote=denman;535503]Here are your parts
EvenNotOdd
#4 Posted : Monday, February 25, 2019 5:31:48 PM(UTC)
EvenNotOdd
United States
Denman, any chance you still have the replacement instructions/manual saved because I need it but that link doesn't work and I can't find it anywhere else? Thanks!
Found it! Here's the new link: https://access.whirlpool.../09001a50801fbb03/dl/pdf
Edited by user Monday, February 25, 2019 6:29:32 PM(UTC)  | Reason: Added reference to user I'm directing question toward
#5 Posted : Friday, March 1, 2019 1:58:48 AM(UTC)
Glad to hear that you found it.
Sorry for not getting back to you sooner but I am no longer active on this forum.
Also I hope your repair went smoothly.
