jdphoto
#1 Posted : Tuesday, April 14, 2009 8:05:49 AM(UTC)
jdphoto
My Dryer won't heat. I need to check continuity on Heating Element and Thermal Fuse, how do you check continuity? Every thing else seems to be running ok.
#2 Posted : Tuesday, April 14, 2009 11:40:54 AM(UTC)
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter
Here are the break down diagrams and Replacement parts for WHIRLPOOL LER7646EZ2 | AppliancePartsPros.com
Estate Electric Dryer won't start - Checking continuity on Timer switch? (Dryer Repair)
by scottietj 7/26/2012 11:10:56 AM(UTC)
