This micro stop working and needs replacement. It is above an oven and below a cabinet.
I can't determine how it is mounted as I don't see any screws or bolts into cabinet above.
Any ideas???
Rank: Administration
Groups: Guests
Probably sits on a wall mounted plate. You might see the plate by removing the bottom panel (where the light and filter are usually located).
