I have a situation with my Washing Machine... It aparently would not discharge the rinse cycle, it just stopped. It did discharge the wash cycle but would not do so for the rinse, it simply stopped partially through. I checked the belt, it is fine. My wife reset the dial @ the required location for the rinse cycle, but after noticing a slight odour of smoke she immediatly shut it off. I think that it may be the dial, but am unable to accuire any specification details, parts breakdown. I will be attempting to dismante the back splash to determine what the cause might be, however what am looking for, possibly burnt wires? Would it be a solonoid, and if so it's location would be where? Your help with the above is greatly appreciated. Kind regards. Home owner.:confused:
Originally Posted by: Randy Martin  I have a situation with my Washing Machine... It aparently would not discharge the rinse cycle, it just stopped. It did discharge the wash cycle but would not do so for the rinse, it simply stopped partially through. I checked the belt, it is fine. My wife reset the dial @ the required location for the rinse cycle, but after noticing a slight odour of smoke she immediatly shut it off. I think that it may be the dial, but am unable to accuire any specification details, parts breakdown. I will be attempting to dismante the back splash to determine what the cause might be, however what am looking for, possibly burnt wires? Would it be a solonoid, and if so it's location would be where? Your help with the above is greatly appreciated. Kind regards. Home owner.:confused: Kindly accomodate the above. thanks,
