gdecker
#1 Posted : Monday, April 13, 2009 8:06:59 AM(UTC)
gdecker
I have a frigidaire gas dryer model# FDG648GFS1 that does not heat. The dryer runs but rarely does any heat come out. The timer switch does not move but only when the heat comes on because I believe there is a heat and moisture sensor inside. What would be the problem? Would it be the timer or something to do with the gas burner?
sidfink43
#2 Posted : Monday, April 13, 2009 1:18:43 PM(UTC)
sidfink43
Hi
If you look at the posts on this site that involve heating problems with gas dryers you will see that they tend to get no response. I think the reason for this is that those of us who reply are electric folks, and I for one am not comfortable giving advice on gas burner issues. I suspect this is true of others as well.
If you have a gas burner issue on a clothes dryer I strongly recommend you get a service call from a qualified gas professional. Saving money on repairs is not worth the risk of the consequences of improperly operating gas appliances.
Good luck, and sorry I cannot be of help.
George C (Dryer Repair)
by George C 10/14/2011 7:57:18 AM(UTC)
sgeorge192 (Washer Repair)
by sgeorge192 3/19/2010 5:17:09 AM(UTC)
George (Washer Repair)
by orenpalmer@mac.com 7/25/2009 11:05:33 AM(UTC)
