edmgriffin
#1 Posted : Monday, April 13, 2009 5:39:21 AM(UTC)
edmgriffin
Water isn't drainning completely and I want to check, clean or replace pump. I want instructions on how to remove cabinet work doing more damage to the washer..
Ed
applianceman
#2 Posted : Monday, April 13, 2009 7:06:16 AM(UTC)
applianceman
To do this, unplug the washer and take out the two screws that hold the control panel in place (one on each side, you may be able to see them in front, you may have to snap off two covers to see them or they may be on the back) then hinge the control panel up. Once its up, you should see a plug attached to the case with three wires - unplug it. Now remove the two clips on each side of the case under the control and lean the case over then slide it out of the way. Clothes Washer Repair Guide
