Libbilu
#1 Posted : Tuesday, November 27, 2007 9:00:40 AM(UTC)
Libbilu
Our refrigerator is growling at me. We've had it less than 3 years, and I figured it was probably due for a cleaning. The manual suggests cleaning the condenser, starting with removing the base grille. I have pushed and pulled at the base cover, trying to wiggle it up/down/sideways. And I know that you shouldn't have to use tools to remove it.
Any suggestions?
Thanks!
Libby
#2 Posted : Tuesday, November 27, 2007 4:19:56 PM(UTC)
The bottom grille usually holding with clip on each side, but a few times I've seen screws too. Look through the grill on sides and if did not see any screws, just pull it out.
Also, remove the bottom cover on the back of the fridge and clean there too.
