This unit is just over a year old and is having a problem with the spin cycle. Everything is working properly through out the cycle. The pump turns on first, drains part of the water, then the spin commenses, but only low speed. It used to start on a low speed then kick to warp speed. Today, I replaced the belt, wasn't in bad shape. I checked the capacitor for the motor, and it read 45 uF, which is good. I'm at a loss for what to do next. Thanks for any help
