I have whirlpool. Whan I turn on burner gets too hot although I set to medium.It happens a lot. Raman
If the heating element stays on High with a different temperature settings then the infinite switch for this burner has to be replaced. - The part number for the infinite switch for 8" burner AP3095444 - The part number for the infinite switch for 6" burner AP3086276 - Here are the break down diagrams for the Whirlpool range Model RF375PXDN0Gene.
