The water dispenser is not working. The icemaker works though. The water works all the way to the bottom of the freezer door, but it doesn't come out of the dispenser. Does anyone have an idea of what it could be and how to take the freezer door apart?
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does try a hair dryer blowing where the water line is at the dispenser for a few minutes
