tswanny50
#1 Posted : Sunday, September 11, 2011 4:32:04 AM(UTC)
tswanny50
The control panel on my whirlpool smooth top stove works perfectly, but the burners and the oven do not heat. Any ideas?
#2 Posted : Monday, September 12, 2011 4:18:13 AM(UTC)
Replacement parts for RF378LXKQ models | AppliancePartsPros.com
Since the oven elements and stove top elements run off of 240 volts I would check that first. The control board and the oven light use half the line, 120 volts.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
