How do I put back on rubber boot & spring at drum side?
The complete instructions you can find in the service manual on pages 79-82. Gene.
Hi Gene, The manual you refer to is only for authorized repairs. Is there anything available for "laymen"? Al Originally Posted by: Gene  The complete instructions you can find in the service manual on pages 79-82. Gene.
Originally Posted by: agiles1960@comcast.net  Hi Gene, The manual you refer to is only for authorized repairs. Is there anything available for "laymen"? Al Al, What exactly is wrong with your washer? What is the complete model number of the washer? Gene.
It looks like the service manual link is now broken. I'm looking for more tips on replacing the boot so that I know I got it on right. I have GLEH1642DS1. Is the service manual available somewhere?
Thanks.
Sorry for the broken link. The instructions are attached. Gene.
Great, thanks Gene! I'm also going to be replacing the rear outer tub assembly (because the bearing went bad). It looks like a full disassemble job. Do you have the proper service manual sections that cover this job (model GLEH1642DS1)? Thanks again.
I'm not sure if it will work with your model. Check it out. Gene.
