Sears Whirlpool Side by Side with Ice/water in the door. Ice Maker replaced four years ago. Recently started forming one or more small (usually) icecicles. Small, Slow, leak, but enough to freeze cubes in bin into a large block, usually at front of bin. Sloenoid water valve replaced, no joy. Suspect some sort of timing issue. Is there an adjustment some where in the gear head?
Thanks in advance for any suggestions.
Remove the plastic end cover from the ice maker and look for an adjustment marked + _. This is your water level adjustment.
Chuckie, Thou art a King amoung men! Sounds like a perfect fix. I'll give her a try after all the munchkin's leave with all my eggs and candy! Thanks, like a bunch, Dude!
Happy Easter to you and yours.
