Would love to hook up a water purifier/filter to our water on the door -- is there such a thing specifically designed for use by this model? Thanks.
All in line water filters are universal and will work with any make and model of refrigerators. The most reliable, the least expensive and the easiest to install is a braided stainless steel water supply line. You will need two pieces. One 12" to connect the water filter to the refrigerator water valve and another one (5' or 6') to connect the water filter to the wall outlet. - The part number for the water filter AP3107794 - The part number for the 12" braided stainless steel hose AP3515740 - The part number for the 5' braided stainless steel hose AP3515761 - The part number for the 6' braided stainless steel hose AP3515741 Gene.
amazing response time -- very helpful -- thank you, Gene!
the Osborns
