I'm trying to fix a freinds dryer, the vents have been cleaned thouroghly. Upon arrival I turned on empty dryer and it was heating fine, I turned it off and back on, and still heated,approx. 10 minutes. So I had some wet clothes put in, and the dryer went cold, a couple minutes into the cycle it warmed slightly but went cold. Took out clothes, turned dial to diferent setting and it started to heat up again. I suspected the thermostat, there are 4 terminals on it, 2 g show continuity and the other 2 dont. whats happening here?:o
2 of the connections are the contacts, the other 2 are an internal heater used to change dryer's temperature. Usually 6,000 to 8,000 ohms. |
THIS FORUM IS DEAD!!!!!!! |
Thanks Denman, I checked the the other two terminals and it showed 480 with the meter set on 20k , is this good and would this cause my problem?
If you provide a Model Number I may be able to find out what it is supposed to be. Model Number Locator |
the model # lgb6400kq0, Thanks again
