Does anyone know which part controls water coming into the dishwasher? I have replace the water inlet valve, float, and pump. The only other part I can think of is the water level contol assembly. Please help. Thanks, Jeff
Jeff,
What exactly is wrong with the dishwasher?
Gene, It won't pull water into the tub. The motor comes on and when I add water it just drains out of the machine. I think it's the water level control assembly because the red float piece seems to be missing the switch? The machine is level and I already replaced the water inlet valve, float and the pump. Is there something I'm missing because I don't want ot go for another $50 if there are other parts that are not working. Please help. Jeff
