rantzy
#1 Posted : Monday, November 26, 2007 11:42:11 AM(UTC)
rantzy
my kenmore coldspot model # 106-51259104 does not work I clean the coil it still does not work. it will only work for 5 minutes when i give the control panel a small bump
kooler
#2 Posted : Tuesday, November 27, 2007 9:39:49 PM(UTC)
kooler
I would check all the wire connections in the control area with this one... Jiggle and inspect any jack/plug connections... Next items to check out are the temp control or the defrost control (AP3773754)... good luck
