Davy99
#1 Posted : Wednesday, September 7, 2011 3:26:54 PM(UTC)
Davy99
I have a Kenmore Dryer Series 500. It was working fine. It will now not turn on. It was operating properly one day and the next will not start.
Thanks,
Dave
#2 Posted : Friday, September 9, 2011 4:47:48 AM(UTC)
Replacement parts for KENMORE 11067522600 | AppliancePartsPros.com
See the attachment for the wiring diagram.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
If the power is OK the next Item at the top of the list is the thermal fuse mounted on the blower assembly.
Part number: AP3132867
Unplug the unit and check the fuse with a meter should be 0 ohms.
Jiggery Pokery method is.
Unplug the unit.
Remove both wires from the fuse, short them together and tape them up so they will not short to the frame.
Plug the unit in and give it a try.
If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires.
Also clean/check your vent system and the blower as these are the most common causes of it blowing.
File Attachment(s):
67522600.pdf (214kb) downloaded 33 time(s).
Kenmore dryer will not turn on (Dryer Repair)
by 3dDetailer 8/27/2012 3:06:35 PM(UTC)
