Dishwasher packed in a month or so back, read that the fact it has water still in the bottom, didnt complete the wash cycle, and that it wont power on, means that more than likely the thermal fuse has gone, tried to find it by the control panel but had no luck. Can anyone please help?
Can get some pictures if needed.
Many Thanks
Please check you model number all ADC's come up as a gas dryer |
THIS FORUM IS DEAD!!!!!!! |
OK now I get it. This is a UK machine Unfortunately I cannot get any info on this unit as this is a US based site. Tried to cross match it to a US unit but had no luck
Could be a door switch is not making correctly. Try pushing the door in a little. On North American units the thermal cutout is often at the end of a 2 wire harness which connects to the control board. Also check the wiring hook up, if hard wired it could be a wire nut was not installed correctly
Sorry I could not be of assistance |
Ah, that explains why im having an even harder time trying to get this sorted.
tried the door already, no luck. thanks anyway for trying! :)
