Mic10
#1 Posted : Wednesday, April 8, 2009 7:58:29 PM(UTC)
Mic10
Changed cycling Thermostat, but that didn't work. I tested it and thought that was it. Now I'm wondering if it is the heating element. How would I check that.
#2 Posted : Thursday, April 9, 2009 12:58:36 AM(UTC)
Replacement parts for WHIRLPOOL TEDS740JQ1 | AppliancePartsPros.com
Here is the wiring diagram
https://www.servicematters.com/d...0Sheet%20-%208528187.pdf
If you have not already done it flip the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Better yet measure the voltage at the plug for 240 volts.
Also check that a wire has not burned off at the terminal block in the machine.
Next would be the heater. Measure it with a meter should be about 9 ohms.
Next would be the thermal fuse (cutoff) should be 0 ohms. This is the one on the heater assembly.
I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
Mic10
#3 Posted : Thursday, April 9, 2009 2:53:43 AM(UTC)
Mic10
Think I've found it. The heater has a broken "spring" or "coil" I guess you would call it. It is not continuous. I'm sure that is it. Thanks for your great reply.
#4 Posted : Thursday, April 9, 2009 3:04:03 AM(UTC)
Yes that would do it.
I always suggest that whenever you work on your dryer that you should clean/check your vent system.
Also if you have to open it up it is a good idea to also do the blower.
