thomasl
#1 Posted : Wednesday, April 8, 2009 5:09:38 PM(UTC)
thomasl
My 3 year old dryer's gas burner lights and then shuts down after 3 minutes or so and clothes don't dry. I thoroughly cleaned the entire vent. I also replaced the Cycling Thermostat & Hi-Limit Switch. I think the problem may be weak gas valve coils and I see from your parts diagram that I would have to change the entire gas valve. Are just the coils available and how could I test them? Could anything else cause the problem?
Thanks, Tom
sidfink43
#2 Posted : Monday, April 13, 2009 1:27:05 PM(UTC)
sidfink43
Hi
If you look at the posts on this site that involve heating problems with gas dryers you will see that they tend to get no response. I think the reason for this is that those of us who reply are electric folks, and I for one am not comfortable giving advice on gas burner issues. I suspect this is true of others as well.
If you have a gas burner issue on a clothes dryer I strongly recommend you get a service call from a qualified gas professional. Saving money on repairs is not worth the risk of the consequences of improperly operating gas appliances.
Good luck, and sorry I cannot be of help.
