acudocdns
#1 Posted : Wednesday, April 8, 2009 12:45:00 PM(UTC)
acudocdns
Do to "no ice" I am going to replace the water valve (which you have sent me).
As I read the instructions it appears that I am the cut the water lines (going to the ice maker and water dispenser) as they are press fit. Then I mark them 11/16" back from the cut. At that point I can press fit them to the new valve up to the new black mark.
Do I have it right??:confused: Of course I will turn the water and power off before I start:)
David
woodchuckie
#2 Posted : Wednesday, April 8, 2009 1:21:12 PM(UTC)
woodchuckie
Yes , the new one is a newer quick release type you just push in.
acudocdns
#3 Posted : Wednesday, April 8, 2009 1:39:07 PM(UTC)
acudocdns
Thanks ... I will give it a go... press fit makes me worry about leaks and I hope the water lines are long enough.
David
