The unit is 2 years old. When the unit kicks into cool mode there is a clinging noise that lasts for about 30 seconds. It literally sounds like a small pebble or something is hitting the fan constantly , but I checked inside and see nothing. This happens EVERY time the unit goes into cool mode. Also, when I turn off the unit it makes the noise again as the fan slows down. Strangely, there is no noise at all on the FAN setting.
This problem just started happening. What can it be? Is it something I can fix myself?
Originally Posted by: vixen4life ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) The unit is 2 years old. When the unit kicks into cool mode there is a clinging noise that lasts for about 30 seconds. It literally sounds like a small pebble or something is hitting the fan constantly , but I checked inside and see nothing. This happens EVERY time the unit goes into cool mode. Also, when I turn off the unit it makes the noise again as the fan slows down. Strangely, there is no noise at all on the FAN setting.
This problem just started happening. What can it be? Is it something I can fix myself? Its a normal sound and shouldnt last more than about 30 seconds
