Our Washer Spins out but the clothes that is on the bottom of the machine are still very wet thats not normal can anyone give us a heads up on this problem with this machine the machine is three years old.
Originally Posted by: Greenmyhs  Our Washer Spins out but the clothes that is on the bottom of the machine are still very wet thats not normal can anyone give us a heads up on this problem with this machine the machine is three years old. my washer is new and will not pump all the water out
But Ricky dont you believe that when a washer spins out that the clothes should be water free and not still half wet if the machine is spinning out properly? Sam
